RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   fokker dv8 ? (https://www.rcuniverse.com/forum/arf-rtf-75/10930186-fokker-dv8.html)
top242 01-27-2012 03:36 AM
fokker dv8 ?
Hi i need one kit of this plane . ist possible?
TomCrump 01-27-2012 04:14 AM
RE: fokker dv8 ?
BUSA has a 1/4 scale kit. http://shop.balsausa.com/product_p/411.htm
I am not aware of an ARF version.
top242 01-27-2012 04:33 AM
RE: fokker dv8 ?
ok very thanzs! but.... ist a big bird! jeje what envergadure?, what engine required? i love my 91 4T
karolh 01-27-2012 06:06 AM
RE: fokker dv8 ?
you will need a more powerful engine than your .91FS for that model.
Karol
Oberst 01-27-2012 06:30 AM
RE: fokker dv8 ?
Yes you will need at the lowest engine size a FS120, but you will need to add considerable nose weight to it. May I suggest a FS150 or higher. Most are using gas engines around 30cc.
Pete
top242 01-27-2012 06:48 AM
RE: fokker dv8 ?
umm, what ist the wing inches?
karolh 01-27-2012 06:53 AM
RE: fokker dv8 ?
Wingspan 82"
Wing Area 1100 sq. ins.
Weight 12-14 lbs.
Karol
top242 01-27-2012 08:14 AM
RE: fokker dv8 ?
wooo! ist big, big! thanzs! i guees ist possible reducction of the plane for adaptation to engine 91.....
Oberst 01-27-2012 02:00 PM
RE: fokker dv8 ?
ORIGINAL: top242
Yes you can, and I've seen a couple people do just that. The kit is 1/4 scale and you would need to bring it down to 1/5 scale. If you have a drafting background and is good in math and making patterns, then you could do it that way. Or, you could have someone copy the plans and shrink it down to 1/5 scale. Many ways to do it.
If you were to bring it down to 1/6 scale then I think your engine might be too big for that scale. I have a 1995 O.S. FS .91 Surpass and I love that engine. It is powerful and quite light compared to the Saito of the same size in my opinion.
I plan on building the Fokker DVIII myself later on.
Pete
top242 01-27-2012 02:25 PM
RE: fokker dv8 ?
thanzs!
panhndl 01-27-2012 04:09 PM
RE: fokker dv8 ?
ARF
http://easytigermodels.com/index.php...roducts_id=298
top242 01-27-2012 04:15 PM
RE: fokker dv8 ?
Very thanzs! ;)
Oberst 01-28-2012 07:21 AM
RE: fokker dv8 ?
He's looking for a 1/5 scale Fokker DVIII. The DVIII you linked him to is a ARF, but it is 1/3 scale it's way larger than BUSA's 1/4 scale Fokker DVIII. Plus he wants to use his glow 91FS and I highly doubt it would even have the power to move it on the ground neither the less get it up in the air. :eek:
Pete
top242 01-28-2012 08:57 AM
RE: fokker dv8 ?
Yes, oberst are you reason, i need for 91 4T , this ist a big big plane ,panhndl !
panhndl 01-28-2012 09:41 AM
RE: fokker dv8 ?
Doh, Tom mentioned ARF, not Top242. My mistake. I was just pointing out that there is an ARF, even if it is a big bird.
top242 01-28-2012 10:06 AM
RE: fokker dv8 ?
OK ;)
Oberst 01-28-2012 03:06 PM
RE: fokker dv8 ?
ORIGINAL: panhndl
Oh, my mistake as well. I forgot what Tom wrote. and had to read back. Duh, for me too. :D
Pete
TomCrump 01-29-2012 03:26 AM
RE: fokker dv8 ?
I mentioned an ARF because this is the ARF forum. I thought that maybe the OP was looking for an ARF.
