RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Bobcat 52 ? (https://www.rcuniverse.com/forum/arf-rtf-75/10989733-bobcat-52-a.html)
PT19 03-07-2012 04:24 AM
Bobcat 52 ?
Iknow this is old but I can't find anything I am looking for. Just bough the plane and need to know the CG and maybe the control throw. It has a TT Pro 61 on it am thinking of a three blade prop, what size? It has the rudder fixed should I put it back are will it be ok as is? Any advise will be welcomed.
opjose 03-09-2012 10:57 AM
RE: Bobcat 52 ?
There are several long threads on this in the Nitroplanes forum.
Head over there.
BTW: It will fly nicely with the TT .61.
I fly mine with a GMS .76 using an 11x8 pusher prop and it SCREAMS...
Remember that you WILL need a pusher prop. A three blader is better for clearance purposes, but your choices are limited in 3 blade pushers...
You'll want a 10x7P if you can get it.
There are several caveats with flying and assembly this plane that you'll want to pay attention to.... it's not a "standard" flyer and it takes a bit of getting used to and proper setup... see those threads for more details.
