RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   built a eflight ARF (https://www.rcuniverse.com/forum/arf-rtf-75/11090692-built-eflight-arf.html)
suzonka 05-22-2012 11:51 AM
built a eflight ARF
Hi purchaced an eflight pt 19 ,when all put together battery all the way forward the first time I flew it I wagged the alerons very sensitive do to tali heavy , it looked tail heavy the cg was way off it was tail heavy , so can I add nose weight Im talking 2 oz to get the CG on the mark
hrrcflyer 05-22-2012 02:54 PM
RE: built a eflight ARF
Suzonka,
What size batteries are you using? I had the same plane that used a 3S 2100 mAh battery. Mine balanced perfectly with this setup. Try to move everything you can as far forward as you can before you add any weight.
Good luck with your plane. You will rfeally like it.
David
suzonka 05-22-2012 03:30 PM
hrrcflyer
thanks , how ever I have made the plane to the instuctions so i added about 2 oz and its perfect on the cg
