RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Battery Question (https://www.rcuniverse.com/forum/arf-rtf-75/11098055-battery-question.html)
brrzee 05-28-2012 07:20 PM
Battery Question
About to put the finishing touches on my Seagull Models Pilatus PC-9 1.20. The reviews used either a 5 cell 2500-2700 maH NiMH battery. My buddy gave me a pretty much new 4 cell 2700 maH NiMH battery and was wondering if that would be alright. Using an evolution 1.20 two stroke with 7 spektrum servos. 2 of the servos being used are for the retract system.
JeffinTD 05-29-2012 03:18 AM
RE: Battery Question
Personally I'd run it on 6v, especially if Specktrum rx. Servos are a bit faster and stronger, and less risk of a brown out.
For the last couple of planes I've set up I went with unregulated Li-Fe, and I really like them.
ahicks 05-29-2012 03:23 AM
There's not much, if any, difference in amperage available to the flight pack when comparing 4 cell NiMh vs. 5 cell NiMh.
I would guess you'd be fine unless extending the retracts while on knife edge using all digital servos?
BarracudaHockey 05-29-2012 06:00 AM
I'd run the 5 cell pack.
How much is your plane worth vice the cost of a battery?
jeffie8696 05-29-2012 07:42 AM
Ihave been using the 5 cell RC car packs, they give up a lot of amperage without voltage drop. http://www3.towerhobbies.com/cgi-bin...LXMUG9&P=K
Charlie P. 05-29-2012 09:02 AM
Attached is a diagram showing how to isolate a battery for the rectacts that is seperate from the receiver power.  That is how I would run electric retracts.
http://images.rcuniverse.com/forum/u...98/Vt56054.jpg
http://www.rcuniverse.com/forum/m_86.../anchor/tm.htm
JeffinTD 05-29-2012 11:12 AM
That looks like a very wise way to set it up. I presume the point is so that if a retract binds up and pulls a bunch of amps, it won't draw the receiver voltage down...
BarracudaHockey 05-29-2012 11:43 AM
Yup, thats exactly the point
