RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Hobbico twinstar (https://www.rcuniverse.com/forum/arf-rtf-75/11131704-hobbico-twinstar.html)
Wolflord 06-25-2012 03:58 PM
Hobbico twinstar
I have a hobbico Twinstar, and have installed two OS SF25's. I am not getting all the fuel from the tanks as the clunks are not pulling down the fuel line. I have never dealt with small tanks before and I am wondering what is a solution.
chris923 06-25-2012 04:14 PM
RE: Hobbico twinstar
Use a more flexable klunk line.
There are more flexable lines then the line that comes in the tank kit.
Chris923
Wolflord 06-26-2012 07:04 PM
Well I used some of the fuel tubing I had in my flight box and it worked. I was not to sure as it still seemed like it was not going to get to the bottom, but it did. I managed to get 12 mins of run time on my two OS25's. I was very happy as I was expecting around 8 mins with full and half throttle. I also managed to get them to idle. I am ready for my test flight on Sunday.
Gizmo-RCU 06-26-2012 07:50 PM
You are doing well for flight time. I have OS 32f's that are about 5 plus mins. at full throttle and you better be landing, period. I use it for my tune-up plane before flying my good ones.....It is fun and everyone enjoys hearing those little sync'ed engines screaming
by. Fun little plane.
Wolflord 07-01-2012 12:55 PM
Well I had it our for it's Maiden today and what a beauty to fly. From factory settings I only added 1 click to up elevator and 1 click to the left. Nice plane to fly and handles the wind well for a little plane. The power to my two OS 25SF engines on a 9X6 prop is amazing, and the sound, a nice purr. Very happy with the plane, the only thing I do not like is the throttle servos rub on the cowl when it is at an Idle.
OldScaleGuy 06-13-2013 10:41 AM
I just picked up a used Twinstar and have it ready for the first flight. Has anyone converted this plane to a tail dragger?
Gizmo-RCU 06-13-2013 07:12 PM
Sems like more trouble than it would be worth.....consider wing location and tailwheel steering?
Ed_Moorman 06-14-2013 01:58 PM
1 Attachment(s)
Excellent flying twin trainer. The trim and later the covering tends to peel off.
For a really fun plane, it needs larger controls. Once my wing covering came loose and couldn't be stuck down, I recovered the top of the wing and installed wider ailerons. The fluorescent yellow is a lot easier to see. At the same time I added floats, pulled the GMS .32 engines and installed Thunder Tiger .42GP engines. It made a really nice sea twin.
OldScaleGuy 06-16-2013 02:21 AM
Thanks for input fella's. I flew the Twinstar yesterday, it a blast to fly. It has Evolution .36's, it flies like a rocket ship.... :D I was really impressed with the little engines. I don't think they had been ran for quite some time but they both fired right up and ran great.
nvr fast enuf 10-03-2013 08:50 PM
This is #2
3 Attachment(s)
#1 Taildragger LA 40's 9-7's no longer with us....Went like stink for 2 years
#2 Taildragger La 46's 8-8's Roundels coming, rounded nose cone coming, rounded rudder installed
http://www.rcuniverse.com/forum/atta...mentid=1926902http://www.rcuniverse.com/forum/atta...mentid=1926903http://www.rcuniverse.com/forum/atta...mentid=1926904
