Oh My look what Hangar 9 has! 8KCAB Decathlon
1 Attachment(s)
Oh my. I couldn't believe my eyes. This may raise the bar for ARF's. it is a 100cc Bellanca Decathlon...
It is a Bit pricy, but still less than some of the jets Iv'e purchased. Wingspan: 137.9 in (3504mm) Overall Length: 96.0 in (2439mm) Wing Area: 3177.0 sq. in. (205.0 sq. dm.) Flying Weight: 38–42 lb (17.2–19.1 kg) Engine Size: 80–120cc gas Radio: 4-channel radio system (minimum) Servos: (4) high-torque, (2) standard servos required Recommended Receiver Battery: (2) 4000mAh Trim Scheme Colors: UltraCote White (U870), True Red (U866), Black (U874) CG (Center of Gravity): 6-1/2 to 7-1/8 in (165–181mm) back from the leading edge of wing Prop Size: 24 x 10–27 x 10 Spinner Size: 4-1/2 in (114mm) Flaps: No Control Throw (Ailerons): Low: 19º up, 11.5º down, 25% expo; High: 26º up, 16.5º down, 30% expo Control Throw (Elevator): Low: 15º up/down, 40% expo; High: 35º up/down, 45% expo Control Throw (Rudder): 27º right/left, 35% expo Main Wing Tube Length: 46.0 in (1168mm) Main Wing Tube OD: 2.0 in (51mm) Tail Wing Tube Length: 14.0 in (356mm) Tail Wing Tube OD: 0.5 in (13mm) Scale: 36% Is Assembly Required: Yes Plane Type: Scale Civilian Experience Level: Advanced Power Plant Size: 4.9-7.2 2-Cycle Gas Recommended Environment: Outdoor Fuel Type: Gas |
RE: Oh My look what Hangar 9 has! 8KCAB Decathlon
Now we can have a shoot out between the Hangar 9, Pilot, and Bill Hempel. I have only seen the Bill Hempel in that size. A little competition is good for the hobby.
But you can't fly it indoors, says so right in specs.:)
ORIGINAL: TLH101 But you can't fly it indoors, says so right in specs.:) |
I love it but wish they would bring it out in 1/4 scale as well. That beast is way too big for my vehicle and storage area.
Finally one that looks scale. H9 did a great job. The Pilot-RC and Hempel Decathlons are fun scale at most. The nose section/cowl are so messed up/goofy looking on those, that I wouldn't want one if it was free. H9 sure could school the other Decathlon mfg's, as Mike McConville has flat nailed this design. This is the most scale kit/arf I have seen since the Pilot/Ok Model 1/4 scale Decathlon kits from years back. Sure wish I had a trailer to haul one of these beautiful airframes. Maybe they will come out with a 1/4 scale version. I'm sure a lot of people would be all over it in a hurry. I hope this one is a great seller for Horizon.
Mr. Yak, the Seagull offering is 1/5 scale and looks pretty nice if you wanted a smaller one. Yeah, I know, too small....
Like the hanger9 the best will order one soon
sj3cub ;I have to agree, McConville nailed it.
what is the chances of floats for it
Your more than likely going to have to build a set of your own. Balsa USA has several nice sets. I'm pretty sure HH has no plans for floats for this model being its a Decahlon. Now maybe if it was a Scout, and not a Decathlon? Who knows though?
