RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Hobbico Hobbistar Tail Dragger conversion? (https://www.rcuniverse.com/forum/arf-rtf-75/1134593-hobbico-hobbistar-tail-dragger-conversion.html)
refurbit 09-13-2003 05:51 PM
Anyone convert the Hobbistar to a tail dragger? I would like to know how you set up the tail? How did you connect the wheel to the rudder for control? What wheel assemble did you use (brand)?
thanks
Texastbird 09-13-2003 11:58 PM
RE: Hobbico Hobbistar Tail Dragger conversion?
I extended the rudder with a piece off a wrecked Hobbistar. I split the elevator and used a "y" pushrod. A Sullivan tailwheed assembly was easily attached to the bottom of the fuselage with the spring actuated from the bottom of the rudder. It works real well. I moved the main gear up to around the leading edge of the wing and used a Dubro plastic landing gear. It's ground handling is steady as a rock, and a lot of fun for shooting touch and go's.
Planedreamer 09-14-2003 11:05 AM
I did that to my Hobbistar one year and the following recovered the whole plane and made all of the surfaces larger.
As a tail dragger, the plane handled FAR better on the ground and I swear, better in the air.
I didn't attach the tail wheel to the rudder directly. Used a rod from the servo. If you're interested in more information, I'll try to dig up an article that I wrote for my club's newsletter.
refurbit 09-14-2003 11:49 AM
Absolutely, if you have the article, it would be greatly appreciated. I'm leaning to-wards controlling the tail wheel via the rudder servo and not directly to the rudder, just seam s easier.
Thanks for the responses everyone.
Kevin
Planedreamer 09-14-2003 07:16 PM
Here's the link to the club's newsletter that contains the article. Since I am the editor, I got the privilege of making it front page.
Good luck.
http://bluemaxrc.com/Newsletters/2001aprilnews.pdf
refurbit 09-14-2003 08:26 PM
Outstanding! this is exactly what I need.
Cheers,
Kevin
