Which adhesive to use?
1 Attachment(s)
About to finish up my Hanger 9 P-51 blue nose .60 and built my own exhaust from balsa and alum. tubing. Need to know what adhesive I should use to attach them to the cowl, canopy glue, epoxy or super glue? Want to do it right the first time!
RE: Which adhesive to use?
30 min epoxy or JB Weld
Ameyam |
Thanks, 30 min it is!
ORIGINAL: JBryson Thanks, 30 min it is! |
Epoxy is my choice also. ;)
I would put some screws thru from the back side for the epoxy to grab onto in addition to roughing up the surface....Just some little # 0 by 1/4" thru from the back side ..
RTV silicone works well for high vibration areas.
I think I might go with silicon too
Me too.I use sikaflex nearly the same thing but you can paint it,silicone scares everything paintwise and sika is so strong,just wipe the surface quickly with acetone,press whatever on and it's there for life,you'll have to grind it off.As said above it's perfect for vibration damping of the part it's attached to too:)
Where can you get sikaflex? I are having trouble keeping my windshield glued. |
| All times are GMT -8. The time now is 08:59 AM. |
