RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   ModelTech Magic CG... (https://www.rcuniverse.com/forum/arf-rtf-75/1154748-modeltech-magic-cg.html)
Dogz 09-22-2003 07:49 PM
Guys this is my first fun fly and I must say it's FUN!... I'm having a lot of problem with flat spins.... we there just not flat. Would the CG play a big part in this??.
I'm running a 52 OSf/s on the plane and balanced right on the CG as per the instructions....115mm from the leading edge of the wing.
Any input would be great.....
The other thing is I'm trying to do is slow the thing down for landings and have the Aileron coming up with the Flap control......is it better up flaps or down flaps?
One last question..in tight loops the plane corkscrews to the left slightly... adjusting the thrust line will this improve things? (bit of right thrust) I have laterally balance the model
