RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Waco ymf5d (https://www.rcuniverse.com/forum/arf-rtf-75/11605272-waco-ymf5d.html)
ptman 10-11-2014 11:39 AM
Waco ymf5d
just bought a new GP Waco and with the engine installed it looks like there is about 4 degrees up thrust on the firewall, Is there anybody that has built this plane and if so, did you have to do any modification to the firewall because from what I understand you should have down thrust on it, any info would be helpful
Mark
Lifer 10-13-2014 04:02 AM
Use a trammel line and verify the upthrust from the centerline of the fuse. If it is there, shim the motor mounts accordingly.
