I maidened my CC last week. Only one flight, as I lost the prop and had to come home and wait for new part. But, she took off very nice and seemed to fly just fine. I had a 15/8 prop on the 95 OS FS and I think it was just a little bit to much prop for a maiden. I will go with the 14/8 this week when we return to the field. I did notice one thing that no one else has mentioned. The CG. I had one of the early versions of the planes, so the CG was printed incorrectly at almost 6 inches back from the leading edge; wrong. The correct location is right at the wing tube. Also, the later versions have the flap control horns in the proper location to allow one channel operation.
Hi All,
I ordered this plane and am waiting for it to come off back order. I am trying to figure out my power plant but having trouble making up my mind. For gas, I was thinking of going DLE20 or O.S. GT22. Any comments on either motor for this plane considering power, ease of installation, modification, etc? I was reading earlier in this thread that the plane is under powered with a 15cc - My original plan was a O.S. GT15. (I'm and O.S. guy) I also purchased the float kit and plan to fly this plane mostly off water in the summer time. I'm hesitant to use gas on the water in the summertime as I tend to fly early in the morning and don't want to chase the plane if it stalls. Any suggestions on the ideal electric motor? I know horizon recommends the power 60.... anything comparable from Rimfire? Thanks for you help! |
You are going to have to cut the cowl for clearance anyway, so I think it would be your choice. I'm still breaking in the OS 95 FS, so I really can't give much info on the equivilant power. At the moment, I'm not impressed with the power on the top end. The DLE will cost a lot less than the OS. I'm not sure how far the prop hub will be forward of the cowl. I think Desertlakesflying has flown with the 15cc and then went to the DLE so he could probably give better info on this. Good luck.
Is the '95 enough power---????
Jury still out on this one. I may have had overheating which precluded a nice full power flight. Flies scale at half. I noticed a CC with a 20 cc RCGF engine for sale on RCU today, out of Tennessee.
has anyone installed a DLE-20 side exhaust in one and if so how much cowl cutting was required---
Took her out again, had radio problems and was lucky to bring her home. The 95 will fly the bird scale; if you like to do a lot of aerobatics, go with a 20cc or even a fs120 (the engine will hang out the bottom). Otherwise, scale aerobatics can be done with the 95 fs. Once I fixed the dang doors (not closing tight w/magnets), I think I'll keep her.
I would love to see a video of that!.. I have a CC electric and it's nice but I keep dreaming of putting a 4 stroke in it. My OS 1.20 might fit but I'd have to hack that beautiful cowl all up and I hate to do that. Do you have any video handy?!
Any update on using an OS GT22 motor in this plane?
4 Attachment(s)
Here she is already to fly :)
more pics landing lights and inst anel
2 Attachment(s)
I have just taken delivery of my CC. I will be using a DLE 20 RA...when I can get one...they are in short supply at present.
Ignition module placement
I just finished mounting a DLE 20cc to my Carbon Cub. Where would be a good location for the ignition module? Has anyone mounted it in the cowl or the motor mount?
I stuffed it alongside the tank, behind the firewall. (I have an Evo 15 in it).
Cmarch01, What power set-up do you have that fits inside the cowl so nicely. Has anyone been able to figure out what fits under the cowl and yet is powerful enough to pull it out of the water? Thanks, Randy |
DLE 20cc
Which one would be the best fit, the DLE20 Rear or side exhaust? And can someone post a pic/pic's of their installation?
Thanks! Mark
Originally Posted by joefly9
(Post 12356463)
I'm assembling a Carbon Cub now. Centered the stab to the fuse, measured from wingtip to front edge of stab. There is a 1/2" difference from one side to the other. The fuse looks straight, so I thought maybe something in off where the wings mate to the fuse. I called Horizon Hobbies and talked to them, he didn't have an answer, so he said he would send me an e-mail and to send them some pics. A couple of days passed and I never heard anything, gave them another call. Talked to a different guy, he said a 1/2" won't make any differents on how it flys, They did send me a e-mail so I sent them some pics. Haven't heard anything back. I was wondering what's anyone thoughts on this. When I build an airplane, my goal is too get it a lot closer than 1/2"
Thanks in advance, Mike |
Mike, yes I agree. I wouldn't be happy with a 1/2". As for "not making any difference on how it flies", it may not but I wouldn't take the chance and how would you really know since you've never flew one that was spot-on to compare it too. Sounds like just a typical response from a used car salesman. Mark
This H9 15CC CUB is really a nice looking but quite heavy bird in air. I powered it by Dualsky 5060 V3 motor at 490KV, a hobbywing 120A V4 ESC, and Redzone 6S4400mah70C batteries. I tried Falcon 16x10 prop but replaced APC 17x7 which was better. It flies scale without any issues. Invert flat spin and knife edge will be amazing too, but I couldn't be confident enough to do so at low altitude. Battery changing is the torment which drives me to the replacement of DLE 20CC now. Thank you all for valuable comments on this topic. I will try to go through your posts.
Carbon Cub C G ??
Originally Posted by althepal88
(Post 12291483)
Thanks, Don |
I am looking to purchase a CC soon and was wondering about putting a Saito FG-21 in it, any thoughts? Pros or cons? This will be my first gasser.
Saito fg21, nice combo, go for it and happy flying
https://cimg0.ibsrv.net/gimg/www.rcu...f835c4d680.jpg https://cimg1.ibsrv.net/gimg/www.rcu...217e6f80d2.jpg https://cimg3.ibsrv.net/gimg/www.rcu...0ca1c125a7.jpg |
suggested H9 pilot model was out of stock, so I made one
https://cimg2.ibsrv.net/gimg/www.rcu...39468f7072.jpg https://cimg7.ibsrv.net/gimg/www.rcu...a3abee5bb4.jpg https://cimg6.ibsrv.net/gimg/www.rcu...1265ca96b1.jpg https://cimg5.ibsrv.net/gimg/www.rcu...38235ebc5a.jpg https://cimg4.ibsrv.net/gimg/www.rcu...7d8f187c5a.jpg https://cimg3.ibsrv.net/gimg/www.rcu...f3d2b6f092.jpg |
Very nice! Was that a "tree" support under the pilot?
I recently made a pilot bust for my FMS Beaver. https://cimg1.ibsrv.net/gimg/www.rcu...f24ec3c964.jpg https://cimg4.ibsrv.net/gimg/www.rcu...326c5c5567.jpg https://cimg6.ibsrv.net/gimg/www.rcu...87b91919f3.jpg https://cimg7.ibsrv.net/gimg/www.rcu...9bb52b0d12.jpg |
Yes that was tree support, Cura slicer.
yours looks great. |
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
