What plane for a .35 AX OS engine?????
A very nice old man gave me a brand new in the box .35 AX OS engine.
I am still in the beginning of training and have more planes than I need right now. But if I decide to put this on a plane what is a good trainer type or easy to fly sport model type plane I could put this on????? Or I may trade it for something else I need. Jimmy |
I have my OS35AX mounted on a Tower Hobbies Uproar. It flies well.
http://www3.towerhobbies.com/cgi-bin...?&I=LXGPG8&P=7 for an ARF, or http://www3.towerhobbies.com/cgi-bin...&I=LXJA52&P=ML for a kit I am using a Macs muffler and APC 9x6 props. http://www3.towerhobbies.com/cgi-bin...?&I=LXZ649&P=7 Live long, and prosper Jerry |
Thanks for the answer I forgot about that plane.
With those fat wings does it land easy?? Jimmy |
2 Attachment(s)
You mentioned that you're still beginning training. If you're not quite ready for something like the Uproar (which is a GREAT plane - no pun intended), you might consider something like a SIG Kadet Mk-II with the wing set to half the recommended dihedral. She's a great trainer, and also a pretty good basic aerobatic plane for learning those maneuvers, and something like that .35AX should power her very well with a 10x6 prop. My own has a 40LA and is really nice in the air.
http://www.rcuniverse.com/forum/atta...mentid=2177151 http://www.rcuniverse.com/forum/atta...mentid=2177152 |
I have an os .35ax on a Wingman 2 ARF by The Wingsmaker. The .35ax is a very strong engine for its weight. It weighs the same as an old os .46la, but turns a 10x6 prop about 900rpm faster, with much better throttle response. The wingman 2 is a pretty fast plane though, The World Models (the wingsmaker's parent company) makes another model called the sky Raider Mach 2, which would also be suitable for this. The Mach 2 is a little bit bigger and more forgiving than the wingman 2.. both planes were designed for a ~12oz engine.
It's a dang sweet engine, and goes like hell on an apc 9x6 and mac's muffler. |
