L-19 Birddog ARF? Help
[s
Hi, I am looking for information on who makes an ARF of the L-19 Birddog. I was given a 72" balsa covered foam core wing with Siver poly covering I would like to build a plane to use this wing.i It has a flat center section and dihedral o n both outer panels. Anybody have an idea of who makes this?ze=4][/size] The airfoil is flat bottomed. Gene blanck [email protected] THANKS |
RE: L-19 Birddog ARF? Help
FYI. A scale Birddog would not have dihedral. The top surface of the wing is flat. Also, since the top of the cockpit is glass, there can be no center section of the wing. Having said that, if you're still convinced that it's a Birddog wing, take a look at the Giant Scale Planes 1/5 scale L-19.
-Ben |
Don't recall any ARF's of this plane....and only two 'kits'.
Jerry |
| All times are GMT -8. The time now is 11:09 AM. |
