RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Fueling Systems (https://www.rcuniverse.com/forum/arf-rtf-75/1166137-fueling-systems.html)
f2titan 09-27-2003 08:29 PM
Fueling Systems
Hey all! We are building the UCD 3D .46. Got the OS 70 mounted last night. Now, I need some help. Fueling systems. I want to know how to set up a system for my UCD. What type of systems are there, what are 2 line, what are 3 line, dot?
What are most using for a set up on the UCD? How is it plumbed? Any drawings I can use? I have a Slimline cap and fitting on my flight box.
Thx...
fossil 09-27-2003 09:28 PM
RE: Fueling Systems
I am using a simple 2 line tank with a Dubro Kwik Fill Fueling Valve. Use the link below to see the Valve.
fossil
http://dubro.com/du-bro/Dub_cat/DUB23.html
jcflysrc 09-28-2003 12:03 AM
RE: Fueling Systems
Thats the ticket! I use these on all my planes.
glowplug 09-28-2003 01:20 AM
RE: Fueling Systems
I like to use a simple 3 line system with this:
http://www2.towerhobbies.com/cgi-bin...?&I=LXAHE1&P=7
f2titan 09-28-2003 12:58 PM
RE: Fueling Systems
What is a 3 line system, and how does it work?
Thx!!
Shihtzutan 09-29-2003 07:08 PM
RE: Fueling Systems
I also opt for the three line system. I used to use the fuel valves from DuBro and GP but they leak easily, especially after 1 season. They also seem very susceptable to dirt and the small size valves don't have dust caps.
The three-line system is simply (from top to bottom) 1. tank pressure 2. fuel fill 3. carb. If you are using a fuel tank with a rubber stopper, you can duel clunk it so you can suck fuel out as well as put it in; otherwise you have to flip you airplane over to defuel it. It's not a big deal and it 100% fool proof. I also like to color code my fuel tubing so I never mix them up. The package the fuel tank comes in should show you drawings and different configurations. Personally I like the Great Planes tanks or the Hayes tanks. I throw the tanks out that come with ARF's.
