Great planes revolver 70”
Anyone know when a lot of these great planes ARF’s will be available again? Tried to contact great planes directly but they didn’t have an optio. To ask about this on their web form. thanks! Erik |
Placing your e-mail at the product page may help.
I have done it before and I have received an E-Mail indicating the product (Model) is back in stock. |
May be picking one of these up. I didn’t realize the amount of servos out there. I have a spektrum receiver so I should prob go with spektrum servos. And recommendations on which ones? |
Originally Posted by ErikElvis
(Post 12566987)
May be picking one of these up. I didn’t realize the amount of servos out there. I have a spektrum receiver so I should prob go with spektrum servos. And recommendations on which ones? I'll not mention names because I don't want to throw anybody under the bus -- but some of the best servos are made by a company that makes one of the worst (IMO) radios. One of the best radio companies (IMO) doesn't even make servos. |
So a touch confused. I have a spektrum dx9 and some spektrum receiver. Will any servo plug into my receiver? I’ve noticed different shapes of the connections on some. also what’s your go to way to add control surfaces to the wings? I tried some of those long gray plastic sticks with a hinge in the middle before but don’t remember how it turned out. |
(Post 12567996)
So a touch confused. I have a spektrum dx9 and some spektrum receiver. Will any servo plug into my receiver? I’ve noticed different shapes of the connections on some. also what’s your go to way to add control surfaces to the wings? I tried some of those long gray plastic sticks with a hinge in the middle before but don’t remember how it turned out. I don't understand the question of adding control surface to wings. |
Thanks for the reply. I just meant what is the preferred hinging method for say the ailerons to the wing. |
(Post 12568019)
What would you recommend for this plane? |
What are you using for an engine? How hard are you planning on flying the plane?
This plane was really popular using a DLE 20, and the rear exhaust version installs with a minimum of cowl hacking. This is a pretty awesome plane, capable of just about anything in the right hands. If you've been flying sport planes for a while and are capable of pushing this plane's abilities, I would sugge3st you use heavy duty everything. Set it up pretty much using the same hardware you would use for a 30-36cc gasser. 4-40 everything, with HD clevises or ball links on everything. So to answer the hinge question, I would use pinned hinges keeping hinge gaps to a minimum, and use blenderm tape (or similar) to seal them from the bottom. One of the most popular planes built, here's Everything you ever wanted to know about the R70 http://www.rcuniverse.com/forum/arf-...-revolver.html You'll need to reinforce the landing gear block. It's the crappiest design ever, was never changed though well known to be problematic from it's introduction, and will pull right out unless landed on it's tippy toes every time. Everyone I know of that didn't do the reinforcement mod furing their build found this out the hard way. You can do a google search on Revolver landing gear mod for more info. Here's a couple of pics. The way I did it was the sheet metal method, with the sheet metal installed between the gear and the fuse. I made it from a piece of alum. roof flashing. -Al https://cimg4.ibsrv.net/gimg/www.rcu...96c029599b.jpg https://cimg6.ibsrv.net/gimg/www.rcu...873ef69546.jpg https://cimg7.ibsrv.net/gimg/www.rcu...17192e97ba.jpg |
Looks good. I did plan on using the dle 20. I’m not sure I have the ability to make a reinforced section like that though with my tools though.
Bending a piece of aluminum sheet metal is pretty easy if you try. So is cutting off a length of angle aluminum purchased at a local hardware store. Either way works fine using just tin snips or a hacksaw.
Ok cool. Are people using blind nuts with the reinforcement or nuts and bolts.
Either way would work fine.
As far as fastening the reinforcement to the firewall is concerned, you could use several short sheet metal screws as long as they were not installed too close to the bottom of the firewall. |
Indeed it is a great planes
