RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   PITTS 40 - KYOSHO (https://www.rcuniverse.com/forum/arf-rtf-75/1186258-pitts-40-kyosho.html)
modlar 10-07-2003 11:44 AM
PITTS 40 - KYOSHO
Hi, :D
I want to buy KYOSHO ARF Pitts size 40 and O.S. 70 II Four stroker.
Some opinions on these forum mentioned a few problems with first series ( not ORACOVER but very cheap cover material,
flutter, etc... )
How is now, after one and a half year of production.
Is it better ?
Which size of servos you use for ailerons ?
Are holes for servos in wings already done ?
Thank you for all opinions.
Peter
Slovenia
modlar 10-08-2003 01:26 AM
RE: PITTS 40 - KYOSHO
Sorry,
but is it possible that NOBODY knows NOTHING about
KYOSHO PITTS or you have just bad memories and do not
want to think anymore on crashed models ?
Thank's anyway .
Peter
Slovenia
polstery 10-08-2003 06:10 AM
I have one, just got it last month the covering is fine, I used standard servos in the wing and yes the servo hole are cut out. If you use smaller servos you will not need to put the little servo cap they supply on because the sevo will not be sticking out of the top of the bottom wing. I have a satio 72 on mine she is fast and will tumble with the best of them..
modlar 10-08-2003 06:46 AM
Thank you for kind answer.
I think, that Kyosho now use a new covering material.
GOOODYYY !
About servos: all clear !
Thank you again and bye from the sunny side of the Alpes.
Peter
SLOVENIA
www.pbase.com/ptg
polstery 10-08-2003 11:17 AM
your welcome, The covering could even be ultra coat but I sure its not monocoat.
