RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   GP Pitts Building Suggestions (https://www.rcuniverse.com/forum/arf-rtf-75/123091-gp-pitts-building-suggestions.html)
sticks-RCU 05-02-2002 09:50 PM
I am going to be starting my GP Pitts in the next day or two and I am looking for any building suggestions. I will be putting a 3.2 in it along with 9001 and 9002 servos. Should I upgrade the hinges, control horns, linkages, etc. Any recommendations would be appreciated.
Thanks in advance.
RCLIVIN 05-02-2002 11:51 PM
hey sticks:
i built mine with a g-62, i used 4 hobbico 110 oz/in servo's on ailerons, 2 on elevators & 2 on rudder, jomar servo reverser on elevators, sullivan steel control horns, i used the ca hinges, if properly installed are good, i installed 2 ernst charge jacks on top of fuse so i could connect both left ailerons to channel 6 & both right ailerons to channel 1, installed 2 1650 mah nimh packs under cockpit area, if you install flying wires use 2-56 screw eyes instead of couplers with holes, they cut the wires, put rc56 glue on all threaded parts of flying wires, on the landing gear i used 50# leader wire from wal mart with springs, make an x with the wires from the top of one leg to the bottom of the other & vise versa, i pinned the firewall with 2 - 1/8'' dowells on each side of the firewall, the lateral balance of my plane was ok & the cg is @ 5 1/2'' without adding any weight, flies perfect, anything else that i can help with i will be happy to just ask
good luck
RCLIVIN 05-02-2002 11:55 PM
hey sticks:
you might check my other post g.p. pitts/g-62 first flights
you might find good info there
