U-CAN-DO 3D 46
Thinking of purchasing one of these.......one question though.....I think in my opinion, that the looks are spoiled by the external servos. Has anyone tried to install them internally? Is it worth the money? any help would be appreciated!
RE: U-CAN-DO 3D 46
I just picked one up and its a really nice plane! The fus is pretty slender though! The UCD was designed for ease and functionality. If you need the sleekness then look at the pattern ships that World Models has. I'm impressed with the last few GP ARF's. They are doing a damn good job...
RE: U-CAN-DO 3D 46
Thanks, I will keep that in mind.....
RE: U-CAN-DO 3D 46
It can be done, and may be something to think about it yoy're using a light engine such as the Saito .72. I mounted a Saito .91 on mine and moved the rudder servo to the wing mounting area and used pull pulls. You may be able to do the same with the elevator servos, but it would be tight.
RE: U-CAN-DO 3D 46
I plan on using an O.S. 46FX for now......and like to move rudder and elevator servos to within the wing area(inside fuselage).
| All times are GMT -8. The time now is 07:21 PM. |
