Question about Hanger 9 Alpha
I just got my hanger 9 alpha and the engine isnt in straight. Is this normal? Its twisted to the left side of the plane.
RE: Question about Hanger 9 Alpha
left bad right good ok when you look at the front the prop shaft is pointing to the left it needs to go right 2 of the 3 at our field was like that takes 1 minute to fix just loosen the mounting screws and turn it to right a little is all it takes:D
well looking at the front facing the prop is going right , which would be the left side on the plane. So thats normal? Just seemed wierd its not straight or point center
that not good turn it the other way
| All times are GMT -8. The time now is 04:09 AM. |
