how is brison?
can ı use brison 2.4 in great planes patty's extra 300 1/4?
RE: how is brison?
After 165 flights, I can say yes you can.
You will not have unlimited vertical and you need to fly with a APC 20x8 or Menz 20x8 to get good strong vertical. The engine is great on that plane. ORIGINAL: memotr can ı use brison 2.4 in great planes patty's extra 300 1/4? |
RE: how is brison?
Ditto
RE: how is brison?
thank you very much!ı will choose patty extra or dave pactrick edge 540 t !can ı use that engine in dp edge 540 or not?what you know about it?
RE: how is brison?
The 2.4 will work fine on the DP edge. Overall, it would be a better choice than the GP Wagstaff, It's lighter and better constructed. It also has very large control surfaces for 3D flight if you so inclined.
RE: how is brison?
If the DP is lighter then I would recommend it.
THe PW Extra can fly IMAC Basic and with energy management, it can do the Sportsman class routines. Forget about anything more complicated. |
| All times are GMT -8. The time now is 06:39 PM. |
