RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Shoestring engine position (https://www.rcuniverse.com/forum/arf-rtf-75/1364377-shoestring-engine-position.html)
RCFlyerNYC 12-19-2003 07:18 PM
I am putting together a GP Shoestring with an OS FS 91 4 stroke for my friend. I'm not sure about the engine position, straight up, or 90 degrees.
Jeff
ziggy99 12-19-2003 10:35 PM
RE: Shoestring engine position
1 Attachment(s)
I have the exact same setup and my engine is mounted upside down. Engine runs like a swiss time piece. Idle is great and the power is super.
I used the 90 header then the stoc header to muffler to try to keep everything as clean as possible. You'll notice in the second pic, I used a Dubro fueler and place a remote glow adapter on the small portion of the fire wall.
I would recommend putting your servos for the elevator and rudder in the rear of the plane for balance as I still had to add 1oz weight to the tail because of the weight of the 91.
Just my 2 cents
Mike
