HELP, mini craft bipe???
1 Attachment(s)
Guys please help me with this one. I bought this little bipe from an auction and I have no information on it. On the plane it indicates that it is a Mini Craft Ultima, which has a WS of 42 inches and it has a 38 inch long fuse. I am looking for the CG and engine recomendations. I hope the pictures help.
RE: HELP, mini craft bipe???
A DA100 should be fine....
No really, how much does it weigh? You might want to try a .46 or .50. |
weigh is 5.25 pounds...
you could run a .40, .46, or .50. depends on what you want - flying or 3D... The .46 should be fine.
a strong 46 or a 50, a 61 would be too much (I'm talking two strokes).
Guys, thanks for the informationon the engine size...
Any one know what the CG or how to find it for this bird? |
Hosam,
Where you ever able to get any info on the Ultima?? I just got one from a guy close by. Unfortunately he doesn't know anything about the plane. Mine has an old Royal .46 on it and Apollo 10 servo's in it. I am going to check it out extremely well and see if I can tell about where the CG is. |
From the leading edge of the foremost wing to the trailing edge of the rearmost wing is the chord. Balance at 28 percent of that measurement.
| All times are GMT -8. The time now is 04:16 AM. |
