.40 size Trainer
What is a High quality ARF Trainer that will work well with an O.S. .40 LA.
Thanks in advance Neil [8D] |
RE: .40 size Trainer
There are quite a few good trainers for an OS 40 LA. However, at the top of my list is the SIG Kadet LT-40... Put on an APC 10X4 prop on you 40LA and you've got yourself a nice flying trainer.
ORIGINAL: Neil B. What is a High quality ARF Trainer that will work well with an O.S. .40 LA. Thanks in advance Neil [8D] I got the low wing SCANNER and I am enjoying every minute of it, mind you I am a newbie. The plane is very neutral in the sense that when you input it just does it for you. You will 'wrestle' less with the plane. Of course you Thunder Tiger trainer is always a good buy. |
| All times are GMT -8. The time now is 12:13 PM. |
