DP Ultimate Motor Mount replacement?
I need a recommend for a motor mount for the DP Ultimate. I have a Saito 180. The included motor mount flexes and causes too much vibration. Any suggestions?
HELP...Vibrating too much
anyone? No one has a favorite motor mount? or a recommendation? Don't leave a vibrating guy hanging!
Hangar 9 Aluminum Mount
I used the Hangar 9 mount on mine. It is aluminum or some sort of alloy. Much stronger than the stock DP mount albeit it a bit heavier. It is the same mount they supply in their 1/4 scale planes but it is available seperately through them for $10 - $15. I have also used the Dubro aluminum mounts with the rubber isolators on this size engine with good luck but do not find them necessary for the $35.00 they get for them. they also require maintenance as the rubber wears out. Hope this helps. If you have not seen these mounts let me know and I can email a pic. cbk
Link to mount
I'm using the db glass mount 120 size..it works ! light! flexes a little though !
| All times are GMT -8. The time now is 03:31 PM. |
