FuntanaS 3D - What Engine?
I just bought a hanger 9 FuntanaS 3D .40. I am trying to come up with the best engine to put in it. I heard that a .46 is not enough to pull good vertical. Anyone know for sure? Also, I heard that a .72 4-stroke isnt enough. Can somebody help me go VERTICAL?!?!?!
RE: FuntanaS 3D - What Engine?
a 72 will pull it but it needs to be propped right,(13x4 or 14x4 for 3D) I have a YS63 for mine Still need to put it together)and the other at my club with the YS63 has great vertical, Many are using 90-ish 4-strokes but bringing up the weight ruins the type of flying this plane was designed for IMHO but that is up to you, It's a great plane.
Dauntae |
ORIGINAL: fairplay I just bought a hanger 9 FuntanaS 3D .40. I am trying to come up with the best engine to put in it. I heard that a .46 is not enough to pull good vertical. Anyone know for sure? Also, I heard that a .72 4-stroke isnt enough. Can somebody help me go VERTICAL?!?!?! |
So at sea level, the saito .72 will pull vertical just fine? What make is the YS63? Please pardon my ignorance...
ORIGINAL: fairplay So at sea level, the saito .72 will pull vertical just fine? What make is the YS63? Please pardon my ignorance... YS is the manufacturer. The 63S and .63FZ are 4 stroke engines. http://www.ysperformance.com/ |
Should I go with a 2 stroke or a 4 stroke?
Go with a four stroke, they produce a lot more torque than a two stroke. This plane is designed for 3D flying, which requires an engine with a good bit of torque. A two stroke will fly the plane, but will not help the plane perform to its capabilities like a four stroke will. Plus, four strokes are just too cool.
John |
I droped an OS 61 into mine and it flys like a kite.
I also recommend a 4-Stroke, I have the Saito72 in mine and im very pleased with it. Vertical performance is awesome. Im using Byron 15% with a 14x4W APC.
1 Attachment(s)
My Funtana flies awesome. It has a Saito 100 and a 15x4W APC prop.
hey cheech. i thought i screwed my cowl up drilling the mounting holes, but yours is like mine, with the drive washer of the engine down low in the cowl hole. I hate the way it looks, but a big spinner hides it well.
sean |
Was it hard to put the saito 100 in your Funtana, Cheech? Would I have to do any mods to the firewall?
ORIGINAL: ifixairplanes hey cheech. i thought i screwed my cowl up drilling the mounting holes, but yours is like mine, with the drive washer of the engine down low in the cowl hole. I hate the way it looks, but a big spinner hides it well. sean |
Yeah, my crankshaft exits a little low. It's the bert you can do squeezing that engine in there. The only mod I had to do was to relocate the blind nuts that thay had for the engine mount. Working behind the firewall was kind of a pain, but no big deal. I really like this combo.
fairplay,
Six Funtana S have flown in our club. The engines have been; OS Max 46FX (2), Magnum 52 (3) and a Saito 72. One aircraft started with an OS 46, but was sold to another member who put a Magnum 52 on it. Our field is about 120 feet above sea level. The Saito is the only one with spectavular vertical performance....not visibly slowing down on the way to nearly out of site. The Magnum equipped planes will climb nearly forever, but obviously are slowing down the higher they climb. My OS powered plane (exactly 5 pounds without fuel) is good for about 100 to 150 of climb before getting sluggish. The other OS powered Funtana (5.25 pounds) was able to perform the entire IMAC Expert sequence as well as holding a hover, but with nearly full throttle, and not enough additional power available to properly "lunge" out of the hover. Other than the hover and the height of verticals, the Funatanas perform nearly identically. IMOH the great difference in performance with the Saito equipped plane is probably due engine ability to swing a larger prop, hence much more pulling power. If your budget allows I would recommend the Saito 72, otherwise pick your 2-stroke. |
So will the saito 72 make it hover? (Thanks for allthe replys by the way):D
Iv read this whole page, and people have been talking about what engine to put in the Funtana, Well i have a saito .72 in mine, everything is perfect in it, and NO i didn't assemble it heavier then the recommended overall weight its suppose to be at. I'm using 15% nitro and a 14.4 prop, Some people say they can pull straight out of a hover with that engine in it, but i cant. i don't know what the problem is, but my funtana will only hover on full throttle {LOL} no room for mistakes, I'm going to try to switch to a 13.6 prop, if that doesn't work, i think I'm going to have to stick a bigger engine in it like a 100.
Go to 20 or 30% nitro and that will give you a boost. You should be fine with than engine unless somethig is wrong with it. Are you flying at sea level? If so it should pull out of a hover very strong. It should hover around 1/2 to 3/4 throttle.
I'm going to try a 13.6 prop. if that doesn't work i guess I'm going to think about buying 20% nitro fuel. but that is very expensive. i dont think all that is going to help though because i would need a pretty big boost in order to fix this problem. no nothing is wrong with my engine, its only got about 15-20 tanks. Brand New. Does anybody out there know where is can get a good type of 20% fuel?? thanks.
saito .82 but i dunno when it will come out
ORIGINAL: squirt I'm going to try a 13.6 prop. if that doesn't work i guess I'm going to think about buying 20% nitro fuel. but that is very expensive. i dont think all that is going to help though because i would need a pretty big boost in order to fix this problem. no nothing is wrong with my engine, its only got about 15-20 tanks. Brand New. Does anybody out there know where is can get a good type of 20% fuel?? thanks. |
JoeAirPort...isent 30% heli fuel not good to put in a glow 4 stroke engine? i thought you shouldent go higher then 20% nitro???
JoeAirPort...i thought you shouldent put 30% heli fuel in glow engines. wouldent it be bad for it....i thought you shouldent go higher then 20%???
sorry for posting 2 times, i thought the first one didnt go through...
| All times are GMT -8. The time now is 12:15 AM. |
