maratuka spit construction help wanted
we are building a spit mk 8 from a maratuka kit , and require some assistance in a few areas ,firstly the kits internal engine support is designed with a 3 degree offset , why is this, and can i cut them out and install a regular engine mount with out disturbing the flying characteristics , secondly as i have a 10 chanell comp radio set, can i sucessfully install flaps to this , or cany i multi task the aerlerons ,i have built before except the maratuka kits comes with a 3 page typed instruction that mentions none of this , an to say the least does not translate from japenese verywell
thanks perth australia |
RE: maratuka spit construction help wanted
Have only the plans of this spit ......
Was wondering if you have found any reviews as well as flying characteristics.??? At what stage in construction you are??? Post some pix...??? Hisham |
Hisham: Firstly, you would get a better response to this in the Kit Forum. Secondly, I doubt dicksallie will respond in any timely matter, seeing as how this thread is a year old, and he only has 4 posts. Start a new thread in the Kit builders or warbird forum, Hisham. You will get better responses there. Good luck!
Yup
Your definitly right!!!! Will be posting a new thread in the scratch building forum soon.. Got to this thread will searching for marutaka.!! Later H |
| All times are GMT -8. The time now is 03:22 PM. |
