RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Dazzler Landing Problem (https://www.rcuniverse.com/forum/arf-rtf-75/189081-dazzler-landing-problem.html)
Jay7318713-RCU 07-09-2002 03:58 AM
I have a Dazzler ARF and when i try to land it, it "bounces" way up it touchs and jumps up. What is wrong??C.G is fine Does is it need more up ailerons or down??
KidVermin 07-09-2002 04:49 AM
Jason:
Come in lower and slower. Your at a speed where the wing still
wants to fly unless your coming in too steep and trying to force
the plane onto the ground. DuBro low bounce tires help too. It
won't help that much to deflect the ailerons up.
Husker Power -- Go Big Red
Randy
f2racer 07-09-2002 06:38 AM
Agreed, the Dazzler should be able to land at walking (or even crawling) speeds, with very little rollout. You may be landing too fast. While faster wheel landings on this model look cool, but sudden jerks on the elevator will cause the big wing to get some air under it, 3 points work better, this model is very good at spot landings due to it's stall excellent characteristics. I went with 3" DBP foamy lightweight wheels. I think that Tower has 2.5" recommended in their manual, but I'd highly recommend 3" if you're flying off grass (purely for prop clearance purposes).
rwh 07-09-2002 02:05 PM
This is common with wire gear on pavement.
You might want to check these possibilities, not enough elevator (plane not able to slow down), or expo on elevator (suddenly too much elevator at flare).
lnorris 07-09-2002 02:31 PM
I agree with the above comments but want to add that the wire landing gear sucks.
I soldered a wire connecting my gear in the middle to take some of the flex out of the wire and it works well.
Also are you mixing in flaperons? Flaring with flaperons and not balloning up takes a LOT of practice as your envelope between flying and stalling gets real small. I just turn of my mixing when I land.
Jay7318713-RCU 07-09-2002 03:38 PM
My Gear
My Dazzler Does NOT have the wire gear i hated it because it always bent back so i replaced with a um i dunno what its called the look at my web sit at my picture you can see it i think
http://www.geocities.com/jay7318713 click link on left side to see my Dazzler
