Kyosho AT-6 Hinge Question
Hello,
I am in the process of trying to finish a Kyosho AT-6 ARF, and repair a little error I made. I made the mistake of using regular CA to glue the ailerons, and now on one side the glue apparently ate away some of the foam in the wing. Im thinking of taking the CA hinges out, filling the spaces in the wing in, and using hinge points instead. Do hinge points work OK in foam core wings? Or does anyone have any other ideas on how to repair the wings and get the hinges to glue in nicely? Thanks Dave |
RE: Kyosho AT-6 Hinge Question
hing points work best in foam core wings .use gorrila glue its a polyurathane glue it foams up and fills all the little holes and spaces between the ridges of the hinge points theres a how to video on installing them om here to
THanks
I picked some gorrilla glue up this afternoon, and i took a look at the how to on this site, so im gonna give the hinge points a shot |
| All times are GMT -8. The time now is 11:13 AM. |
