RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   P/P elevator for Lanier 540T (https://www.rcuniverse.com/forum/arf-rtf-75/199282-p-p-elevator-lanier-540t.html)
DanS 07-17-2002 08:57 PM
Anybody using a pull pull evelator setup on the 73in Lanier 540T? If so could I get some pics or details. I was thinking of something like the DP extra setup. Thanks.
CAP232CM 07-17-2002 10:34 PM
I only know of one guy using this setup his name is elderair. He's using a bellcrank postioned where the elavator servos would normally go in the tail. You can buy the bellcrank from central hobbies.
You run your pull cables to the center of the crank then use normal linkage to hook up the elavators on each side. Sorry don't have any pics but maybe this will get you started. Good Luck!
rcavi8ter 07-17-2002 10:50 PM
Bell Crank
I am using a bellcrank in my Edge and love it. I made a hatch in the bottom of the fuse so I can get to the bellcrank then ran a DaveBrown Fiberglass pushrod to the tail to have ver positive set up. I will post some pics tonight after I get off of work.
Chris Puckett
Puckett Model Aviation
