Sig Sukhoi
I have read all the other posts about this plane, but I have one question.
What needs to be modified while assembling the kit. Any areas that need beefing up or something like that. Thanks for you time. Scott |
RE: Sig Sukhoi
Scott there are two thing I did to mine. One I glassed the center of the wing after I joined it. Some of the early ARFs folded the wing in flight. It didn't add much weight and was good piece of mind. Two, the top of the firewall would flex down when I revved up the engine. (ST3250) So I drilled three holes through the firewall and into the bulkhead with a 1/4" bit. Then epoxied dowel rods in place. I also added a better block with blind nuts to hold down the hatch in the same area. The wood screw vibrated loose. It flew great until I stripped out the AILE servos and lost it. It will be rebuilt the winter.
David |
RE: Sig Sukhoi
1 Attachment(s)
Knife edge into barb wire result below.
David |
| All times are GMT -8. The time now is 09:19 PM. |
