RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Help! Trying to ballance from "wing root"? (https://www.rcuniverse.com/forum/arf-rtf-75/209284-help-trying-ballance-wing-root.html)
stop_the_spam 07-27-2002 02:34 AM
Help! I'm trying to ballance my Magnum ARTF and the instructions say 120-130mm from the wing root. I'm not sure what the wing root is! Is it from the leading edge, or from the trailing edge? Or maybe from the bolt plate?
Adrian
TIGER2PLANE 07-27-2002 04:26 AM
I would say 4-3/4 inch from the most forward part of the wing, or the most forward of the center of the wing where it is glue together..
4*60 07-27-2002 06:39 AM
My understanding is the wing root is where the wing meets the fuselage. Nobody has ever said otherwise.
Measure 120-130mm back from the leading edge at the fuselage. To start with set the CG at 120mm back from the leading edge at the wing root.
