pattern ARF for .60-.90 2 stroke engine
What would you recommend for an ARF F3A plane?
RE: pattern ARF for .60-.90 2 stroke engine
ARESTI
There will be so many ...
CMPro/GSP - Swallow Kyosho - G Trick WM - Zen The G Trick is a great plane. The Swallow is pretty decent too. |
I am partial to the Zen series if my wallet would cooperate I would have the 120 sized one. I currently have the Fascination but thats more of a 40 sized plane. Try the Zen 60 or GSP Swallow
you also might ask this same question in the Pattern forums, there are many knowledgable guys there who might have suggestions for you. good luck matt |
The Exelleron 90 is a good flyer and a bit more affordable then some of those mentioned above. The Aresti although a good flyer is too small for a 60/90 2 stroke.
There are several sizes of the Aresti from 40 size up to 2 meter.
The G-Trick is an attractive plane, but all the fiberglass parts are very thin and very low quality and started cracking before I got it to the field the first time. It is waaaaaay overpriced. YS .91 with a 14X10 APC prop and Powermaster YS 20/20 fuel was marginal. Flew OK, but was really puny in the vertical. Put in a YS 1.10 and that made it perform nicely. Entire cowl floor ripped out on the first semi-hard landing. I wouldn't buy another one.
I think the GTrick looks great and flies nice but yeah ... in Malaysia its about twice the price of a GSP Swallow. I got the Swallow and hope to take her up soon ... I got a YS110 for her!!! Hehehee ...
| All times are GMT -8. The time now is 07:58 AM. |
