harrier 3d CG Question
how far back from the leading edge are you balancing your Harrier for best 3D ?...And are you balancing it inverted?...Thanks...JW
RE: harrier 3d CG Question
Mine is 180 mm from the leading edge.
JW, mine is also 180'ish give or take a few mm. I didn't invert mine to balance, shouldn't much matter.
Hint: didn't have much luck with a spoileron mix, but if you can rig up a snap flapperon mix it works great for square loops, waterfalls, etc. Ed M. |
