Phoenix Models Extra?
This is probably a long shot, but I'm stuck.
Has anyone put a SuperTigre G51 or any engine for that matter in a Phoenix models Extra 300? I cant get it to fit heres why: I'm using a Slimline Pitts style muffler and the engine mount is in the way and there is no way to fit the giant stock muffler The directions say to mount the engine so that the front of the engine thrust washer is 4 3/4 inches from the fire wall and that still is not enough forward The factory installed throttle tube is nowhere near the throttle arm. Does any of this sound familiar? I would appreciate any and all suggestions/advice. thanks, Chris |
RE: Phoenix Models Extra?
I thought Id float this to the top and try again, sorry.
chris |
I have a Poenix extra, but unfortunately I have not built it yet. I few pic would help if you have a camera. I assume you have moved the engine out as far as it will go on the mount and you are still not out the 4 3/4 " you need. This length is only so that the cowling will fit. Try putting the cowling on and move the cowling toward the canopy to see if you can get it close enough. If that doesn't work you can add 1/4" spacer on the firewall, drill through it into your firewall and put new T nuts through both. As for why the pitts muffler does not work, I am at a bit of a loss. Are you saying that the muffler comes into contact with mount? Are you mounting your engine with the head down or sideways. The pitts mufflers are made for one or the other. Is your mount upside down as well?
As for the throttle tube. Just drill another hole and move it to a location that will line up with the throttle arm. Plug old hole. |
I guess I have alot of mickey mousing to do with this setup. thanks and let me know how yours works out.
chris |
Yo, Big Bird! Get with your cartoons. IT"S M-I-G-H-T-Y M-O-U-S-E.............:D
| All times are GMT -8. The time now is 10:29 PM. |
