Dumb U-CAN-DO Question
I am putting together a 60 size U-CAN-DO and have what is probably a dumb question. I am installing the aileron servos. The instuctions say to tie the string to the servo wire and then pull the center of the string out of the servo hole and then pull the wire through the wing. Question: Is there supossed to be a hole in the center of the wing to pull the wires through? Mine does not. Where does it go?
Thanks |
RE: Dumb U-CAN-DO Question
The hole is there. You just need to cut the covering off of it. It is closer to the leading edge in the middle of the wing on the top side.
If you have a soldering iron use that to make the hole. You have to feel around to find the holes though.
Thanks guys - found it.
Pete |
| All times are GMT -8. The time now is 09:48 PM. |
