Hangar 9 Aresti 40
Want to turn my Satio 72 upright on my Aresti 40. Can I just turn around the engine mount or will the engine then be too high on the plane??
RE: Hangar 9 Aresti 40
you can do that but it will get you laughed off the field it ruins the looks[:'(]
As long as it run. The Saito doesn't like to be inverted...
Higher RPM since the plug is always soaked. Don't want onboard glow. Will move the blind nuts and try a lighter engine mount to boot! thanks. |
you have a tuning problem saitos love to be inverted just tune it right it will not run good till you use at least two gallons of fuel it will be fine inverted and look good
Is 10% nitro ok?
it will run bad on it i'd use at least 15% i use 30% in mine and can idle 500rpm lower on it it makes a huge different
All my saito's are inverted, they love it. You have other issues.
Don't run less than 15%, 30% will really get its heart pumping. I use 18% oil.
| All times are GMT -8. The time now is 01:30 PM. |
