RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Engine mounting help (https://www.rcuniverse.com/forum/arf-rtf-75/2515569-engine-mounting-help.html)
NJ Flyer 72 01-08-2005 09:32 AM
1 Attachment(s)
Hello, I'm in the process of putting together a GWS Win Wind, and need some advise on installing the engine (all my other arf's had the holes pre-drilled). The engine mounts were already installed and the recommended engine (OS 40 LA) fits perfectly.
I am going to use screws and nylon lock nuts... but my main question is--> When drilling the holes, do I make the holes big enough for the screws to slide through or do I want to have to make some resistance for the screw to go through the engine mount ?
Also, can someone recommend the proper size screws, nuts, drill bit etc... ?
Thanks, NJF72
MinnFlyer 01-08-2005 09:51 AM
RE: Engine mounting help
As long as you're using lock nuts, make the holes a slip fit. That is, there shouldn't be any resistance, but don't make it too sloppy.
I don't know the exact size off hand.
NJ Flyer 72 01-08-2005 10:06 AM
Rgr, thanks Mike.[sm=thumbup.gif]
