RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   quick question (https://www.rcuniverse.com/forum/arf-rtf-75/2648521-quick-question.html)
rob6894 02-11-2005 11:54 PM
quick question
I have a powerflite redundant battery li-ion pack. I dripped a little ca on one of the wires on accident while working on my plane well when I was moving one of the wires the sheeting cracked in 3 spots Right next to each other where the ca dripped it does not look like the sheeting cracked all the way to the metal wire but close. I just wrapped it up good with electrical tape I tested and everything powers fine. I assume this will be ok since the wire itself never got severed but I want to be sure using the electrical tape is the right idea.
Rob
BasinBum 02-12-2005 12:48 AM
RE: quick question
By sheeting if you mean the insulation around the wire it is only a problem if both wires insulation is cracked and there is a chance they could touch. If you wrapped the red and black wires seprately with electrical tape it will be fine.
