Antenna questions
Hi all,I would like to know more about the whip antenna for the rx.How is it attached to the rx and do I specify what brand of rx I am using?.Where do I get these? Also,what about the so called "rubber duck" antenna for the tx that some fellows use ? Are there different brands for different txs and what is the advantage vs the standard tx that comes with the tx?.Thank you--- flyboy
| All times are GMT -8. The time now is 10:40 PM. |
