RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   U Can Do 60 wing rock (https://www.rcuniverse.com/forum/arf-rtf-75/2904325-u-can-do-60-wing-rock.html)
sonicboom 04-23-2005 08:18 AM
Hi guys.
I there any particular trick to get the U can Do to Harrier or elevator. YS110 16 x 6. cog 160mm. The thing is so unstable. I have tried ailerons up and down!
Sturtz 04-23-2005 08:45 AM
RE: U Can Do 60 wing rock
I moved my CG back 10mm from the manual's 120mm. CG at 130mm. Will now do harriers without even working at it . Rock stable. Will harrier land into slight breeze at a dead stop. No wheel roll at all.
E-Mo 04-23-2005 08:52 AM
Did you check the lateral ballance?
might need to add some weight to the wing
usualy the left wing, check it out.
sonicboom 04-24-2005 08:41 AM
Sturtz was yours the U can Do 45 or 60? My COG is at 160mm.
