RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   prop size (https://www.rcuniverse.com/forum/arf-rtf-75/2984928-prop-size.html)
phillyfry 05-17-2005 07:15 PM
prop size
just finihed a 4* arf would like to no if a OS 52S is a good engine ti install and what size prop would be best thank you
Primodus 05-18-2005 09:44 AM
RE: prop size
Having had this exact combo, I recommend an 11x7. The 52FS is a great motor for this plane and will pull it around with plenty of power. It also helps slow it down at low idle for easy 3 point landings. Your gonna love this plane![8D]
tIANci 05-18-2005 11:05 AM
RE: prop size
I tried a 12x8 on a Saito 56 before, I think you might be able to get away with a 12x6 on the OS52, it will give you more thrust. Try and see if it can tach at about a minimum of 9,200 RPM.
