RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   CMP Hellcat or Hangar-9 P40 (https://www.rcuniverse.com/forum/arf-rtf-75/3018066-cmp-hellcat-hangar-9-p40.html)
Aero D 05-27-2005 06:32 PM
I'm torn between puchasing the CMP Hellcat or the Hangar 9 P40. I want a nice looking warbird ARF that I can hang my Satio 120 on and that assembles well and flies great. Oh, and yea, I want it for under $250.
Any suggestions??
Hellcat716 05-27-2005 07:55 PM
RE: CMP Hellcat or Hangar-9 P40
1 Attachment(s)
If you are going to use that 120 I would recommend the Hellcat. You will need to purchase retracts for the Hellcat if you do not want to use the supplied fixed gear. The 120 in the P-40 would require a lot of tail weight. They both fly really well. Here is a picture of my Hellcat. I was waiting for the retracts to arrive. I installed Sierra Percision retracts and they are awesome. This Hellcat flies really nice. The span is about 10" bigger than the P-40 and will weigh about three to four pounds more. I am using a YS 120 in the Hellcat which is a perfect match for this plane.
kmtranmd 05-28-2005 12:26 AM
I'm using the Saito 100 in my H9 P-40 and it's more than enough power. I think the 120 is overkill for the H9 P-40, probably better for the CMP P-40. I'm waiting for CJM to make the 100 degree rotating pneumatics for my P-40 because the stock mech retracts are worthless piece of crap.[&o]
Aero D 05-28-2005 08:06 AM
[8D] Wow, that bird is nice! Is that a CMP? Is the wing covering that comes with the CMP Hellcat any good?
How much do those Sierra Retracts cost? Do they come with everything you need?
Hellcat716 05-28-2005 10:29 AM
Yes, that is the CMP Hellcat recovered and repainted. The stock covering and paint is marginal at best. The Sierra retracts with control valve will run you about $285.00. The best retracts that I have ever had.
LDM 05-28-2005 05:21 PM
Go with the CMP P40 , I got one its a really nice plane . howevere you may need a bigger motor but what the hey , this hobby is all about build , fly & buy . it one big cycle of life :D
DiscoWings 05-28-2005 11:55 PM
Hangar 9 will most definatley fly better because it is lighter and designed more to be a sport plane that looks like a warbird.
CMP planes fly more scale and therefore are trickeir to fly.
Personnaly, I admit the covering job on the cmp is cool and you can add details to it, but in the air I would have to say ultracote looks better.
Remember, it will be a lot easier to repair the hangar 9 arf then a cmp plane...
I say go with the p40 from hangar 9
LDM 05-29-2005 06:31 AM
You do have one more option if you love P40ties the way I do !!! The VQ p40 , tan and green version . Do a search Richard L did an online build on the plane . It has flaps, real thick tail flying surfaces , comes with oleo struts , real nice detail , very good hardware ect .
I was very impressed with the quality of the build , all sheeted surfaces .
Now it fly like a warbird , its heavier then the H9 P40 but I still feel its worth looking at .
ram3500-RCU 05-29-2005 08:57 PM
My vote goes to the Hellcat. It has a roomier cowl for that 120. It also has a bigger tail and flies easier than the P40. It was a better flying plane in full scale so it just figures. I also believe that repaires made to the CMP version will just make it look more WW and thus more scale. It's all good.;)
LDM 05-30-2005 06:55 AM
I like the hellcat , probably get one at Christmas , (can you explane repairs??) I assume you mean modifications by the modeler.
My problem with the hellcat vs the P40 is the short nose , I also dont think you can compare flight characteristics unless the same airfoil and scale downed demensions are used as in the real plane ;), I dont know if that is the case for either plane from CMP . Its a good point but I have to do the math to see how the measure up .
Aero D 06-11-2005 09:38 PM
What size prop re you using on that Hellcat?
melvinCL 06-11-2005 10:48 PM
i bought a cmp f6f where can i order a set of sierra retacts for it and part numbers needed and any building info you can send with photos and any extra material needed
tnks melvin [email protected]
Hellcat716 06-11-2005 11:39 PM
It is a graupner 14x7.
