RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Plane for a 35CC gas engine (https://www.rcuniverse.com/forum/arf-rtf-75/3089482-plane-35cc-gas-engine.html)
bubbagates 06-19-2005 07:56 PM
I would like suggestions for a new plane. I have a Roto35vi that turns a Bambula 20X8 at 6600rpm and it was in a plane that I dumb thumbed into the ground today.
Aerobatics is a must 3D is not a need but would be nice. I'm open to all suggestions so please fire away
TIA :D
I_Fly_Coolers 06-21-2005 09:45 PM
RE: Plane for a 35CC gas engine
What about this Cap 232, at $250 it's cheaper than a stick!!! http://www.rcsuperstore.com/Products...aft/eaa232.htm Same plane as Chip Hyde Cap-x. Planning a Ryobi 31cc w/electronic ign for mine. There's a build thread here too!!!
zx32tt 06-22-2005 06:51 AM
You may want to look at the 1.20 size WH Edge 540. The Goldberg Sukhoi ARF is also a possibility.
Z
bubbagates 06-22-2005 06:54 AM
ORIGINAL: I_Fly_Coolers
That's weird you suggested that. This was in a Kangke Cap232-120. Kinda heavy. Flew well until I dumb thumbed it but it looks promising Thanks :D
bubbagates 06-22-2005 06:59 AM
I didn't consider the WH 120 Edge but to tell you the truth I have 2 CG Sukhoi's One with a YS140 and the other with RCIGNITION's G26. One's for 3D the other is for IMAC.
I a little concerned on wing loading. This engine is 3.1lbs with the ignition, muffler and battery.
But I'll give Tom at WH a shout to see what he thinks. I have his Ultimate what a plane [X(]
pettit 06-22-2005 08:37 AM
The original Dan Santich 80" UltraHots was designed around a Quadra 35. It took less than 48 hours to go from a pencilled sketch to a flying plane with a Quadra 35 on the nose.
The Roto 35 is a lot lighter than the Quadra and would make the UltraHots really perform well.
Plans are available somewhere, and you may even be able to find a kit.
SJN 06-22-2005 10:03 AM
1 Attachment(s)
GSP/Jamara/Flair Yak-54 flys very nice with the MVVS 35.
sir-crash-alot 06-22-2005 10:08 AM
1 Attachment(s)
edge540 from powerlinehobbies.com i have that exact engine althought you will need a supersonic muffle to have good verticle. other that that a qq yak.
