RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Odd control problem BeginAir (https://www.rcuniverse.com/forum/arf-rtf-75/3300696-odd-control-problem-beginair.html)
jtkirk01 08-26-2005 08:35 AM
Hello all! I'm relatively new to RC airplanes and I recently purchased a BeginAir RTF kit from parkflyers.com. It is a very basic 4 channel plane. I recently lost the first one in a tree due to a control problem with the plane. Whenever I apply left or right aileron I lose power to the engine until the servo has extended fully. Other than that its fine. Does anyone have any ideas on what could cause a problem like that? My thanks for any assistance!
JeffreyDWarsaw 08-27-2005 11:12 AM
RE: Odd control problem BeginAir
I have a BeginAir and I have noticed that the engine power drops off when a servo is activated. If your throttle setting was low the power drop off might be enough to stall the engine. Did you cycle the battery twice before the first flight? If you didn't cycle the battery before flying the first time you would not have a full charge and that could also contribute.
