RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   AVISTAR (https://www.rcuniverse.com/forum/arf-rtf-75/3370334-avistar.html)
jurjevib 09-18-2005 03:38 PM
AVISTAR
I would like to buy a set of Avistar wings or get a template of thew ribs[:o]
S-a-v-a-g-e 09-18-2005 04:51 PM
RE: AVISTAR
OK,............. Look on Ebay and in the RCU market.
jurjevib 09-22-2005 06:59 AM
RE: AVISTAR
[&o]tried that no luck
ORIGINAL: S-a-v-a-g-e
red head 09-22-2005 03:22 PM
RE: AVISTAR
Unless you get real lucky, you would probably be better off just buying a whole kit, it is normally cheaper in the long run then trying to buy a wing kit.
Can't you get a pattern off the wings you have ???? If you have one. Sorry I can't help more. ENJOY !!! RED
lt-40 flier 10-02-2005 09:49 PM
RE: AVISTAR
Just saw a set of wings in an Ebay on line store but the cost was$72 plus shipping.
Avistarpilot 10-02-2005 10:03 PM
RE: AVISTAR
I am in the same boat you are..I recently clipped a tree branch with my Avistar and put a hole in my wing tip, in the fuse, and broke my tail off...but after lookin im just going to repair in myself. I just made a new spar from an old on(i just need the leading edge) Towerhobbies has wings...but they are kinda pricy. How bad is the damage?
-Dustin
pache11 10-03-2005 08:07 PM
RE: AVISTAR
I bought my replacement wing kit on ebay. I then sanded the wing root vertical to remove the dihedral and put a 2" fiberglass reinforcement. It flys so much easier and more acrobatic. It will fly inverted with just a touch of down elevator and rolls are much more axial.
