RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Oleo's (https://www.rcuniverse.com/forum/arf-rtf-75/3420605-oleos.html)
ajensen3 10-04-2005 08:06 AM
Oleo's
What are Oleo's? I'm going to replace the retracts in my H9 Miss America P51 60 size with Spring Air retracts. But I was asked if I wanted OLeo's. ????
RK-Aircraft 10-04-2005 10:22 AM
RE: Oleo's
AJ,
These are the compression struts in the gear. The other choice is heavy wire struts which are not scale. The oleo is a tube in a tube with a concealed spring that lets you get away with a less than perfect landing.
cat5752 10-04-2005 12:49 PM
RE: Oleo's
Oleos will allow all the force from the bad landing to gather power from the compression of the springs within them. One of two things happens at this point; the plane rebounds like Michael Jordan (BOINGGGGGG), or the landing gear explodes through the top of the wing:D
All that said, they are cool, and will work out better than straight wire, or even wire with a coil spring.
FBaity 10-04-2005 03:12 PM
RE: Oleo's
A Oleo strut is actually a hydraulic cylinder with a orifice that controls the fluid flow around the piston to cushion shock forces. A spring strut is just that: a spring that cushions the shock force.
