RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   DP Ultimate Pull-Pull Set-up Elevator ?? (https://www.rcuniverse.com/forum/arf-rtf-75/347928-dp-ultimate-pull-pull-set-up-elevator.html)
bralex 11-04-2002 03:05 AM
Hey Guys! Does any of you DPU fans have the ability to post a few pics of the pull pull elevator set up. The directions are a bit unclear and haven't been able to find any info on a search. Can't wait to get this one up and would appreciate any help!! Thanks in Advance!!
bill white 11-04-2002 03:57 PM
I'm not sure what the confusion is about, but I have been flying a DPU for about 2 years w/the pull-pull elevators, as prescribed in the instructions, and they work fine. I am unable to send photos, but the procedure is simple. Merely thread 2 cables from each side of the servo output arm to the top, and bottom of each elevator half. It looks like you have a lot of cable in the kit, but when you finish, you will have less than 6 inches left. ( I.E. from one side of the output arm, thread the cables to both bottom linkages, on each half of the elevator, and on the other side of the output arm, thread both cables to the top of each elevator half).
Hope this helps
Bill
bralex 11-04-2002 06:08 PM
Bill, Thanks for the reply to the post! Based on the nature of your response regarding my confusion, I thought to check the manual one more time. The reason for the confusion is because there are nine pages missing from my manual. Page 10-18 are no where to be found. I'm sure Dave will be willing to remedy the problem. Thanks again for your help!
BRoskovics 11-05-2002 04:18 AM
DP Ultimate Manual
Don't Feel bad, I had a couple of pages from the Extra manual inserted in my Ultimate manual.
