U Can Do 3D
Hi,
I just got a new U Can Do 3D .46. Now I'm trying to decide wether to put the OS .46 AX or the EVO .61 NT. What would you recommend? |
RE: U Can Do 3D
I've flown one w/ an Evolution 46. It seemed like it needs more omph. For a 2-stroke, it needs at least a good .50+. On the other hand, the Evolution .61 may be too heavy (25.44 oz including muffler). That plane really would benefit from a 4-stroke. A few of my friends have this plane w/ OS .70 4-stroke, and it seems about right. Magnum's new .70 4-stroke would be perfect for a lower cost. .70 4-stroke weighs about 22 oz including muffler. I guess the .61 Evolution is not that much heavier than an OS 70 4-stroke.
A perfect engine for this plane is Saito 82, weighing just 19 oz including muffler, and has the power of 91 4-stroke. |
RE: U Can Do 3D
I have had several of these planes. A good strong .46 engine will work just fine. I believe the Tower .46 muffler will fit that engine. I had an OS .46 FX on my current UCD, using a Tower Muffler, 15% Byrons and either an APC 12X4 or 13.25X3.75W prop, it worked just fine and hovered reliably. Once I wore the .46 out, I installed a Magnum .52 with the same Tower muffler. That engine is nearly worn out as well, but still under warranty. The plane rocks with this engine. Sean's advice to avoid the .61 is good advice, not only is that too much engine, the wing loading would suffer due to all the weight you would need to add to the tail to balance the plane.
I used an OS .50 SX on mine for a while and it worked pretty good, but like the Magnum better, once I got it broken in. Many members of my club are using the OS hype .50's on thier's with 20 to 30% nitro. They really rock and spin an APC 12X4 well over 16K, hover about 1/2 throttle and have unlimited accelerating vertical. If you consider a 4 stroke, a Saito .91 or .82 is the way to go, due to them being the lightest of the class. There are several threads about this airplane on the 3D and sport areas that you might want to visit. You also may want to set up your account to take PM's. Hope this helps, You'll love this great airplane, make sure you read up on the landing gear fixes also, If you fly aggressively off of grass and do harriers, you will be repairing the landing gear. Happy Landings! |
| All times are GMT -8. The time now is 06:13 AM. |
