RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Help with Moki in Wm Extra300S (https://www.rcuniverse.com/forum/arf-rtf-75/359848-help-moki-wm-extra300s.html)
Crash90 11-11-2002 02:25 PM
Last night I installed the motor mount that came with my WM Extra 300S. I tried to install my engine and it wont fit between the bars. I'm not sure what to do as the firewall is already drilled and the blind nuts are already glued in. Any suggestions. It is a Moki 2.10.
2 wing pilot 11-14-2002 09:50 PM
Its not to hard to fix the problem. Just remove the blind nuts, epoxy dowels in the holes left behind and redrill new ones in correct spot.
