help transportation problems
I'M TRYING TO FIT A 102" YAK IN A IZUZO RODEO!!!!!!!
IF I COULD MAKE THE RUDDER REMOVABLE IT WOULD FIT PERFECTLY!!!! DOES ANYBODY KNOW ABOUT A CAOMPANY THAT MAKES REMOVABLE HINGES???? PLEASE SOMBODY HELP???????????[:o][:o][:o][:o][:o][:o][:o] |
RE: help transportation problems
You can use dubro or klett large hinges and use a single wire for all of them. just bend the end over and you will be able to straighten it and remove the rudder.
:D Derf |
Where is the plane getting not fitting? Theres gotta be a way. Its amazing what models i could fit in a honda civic. Just need a little planning.
| All times are GMT -8. The time now is 08:47 PM. |
